AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
setting Projection system on dwt file (Autocad Map 3d)
1 REPLY 1
murali.pandey
818 Views, 1 Reply
Can I define a projection system in drawing template file(dwt).
If yes then how?
Murali
1 REPLY 1
Daniel.Du
in reply to: murali.pandey
I did a quick try in Map 3D 2013. You can assign a coordinate system from "Map Setup" -> "Assign" button in "Coordinate System" tab, and save it as DWT file.
Daniel Du
Developer Technical Services
Autodesk Developer Network
”Boost
