AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
"Stylizing"
2 REPLIES 2
rsniff
699 Views, 2 Replies
"Stylizing"
I am having an issue with certain maps taking a long time to open.  There is a window that opens up that says "Stylizing...."  and it just sits there not responding.  It seems to happen after I connect to external data through Data Connect.  Also sometimes after I Mapimport a shapefile.  I am inexperienced with Map 3D so please ask me questions if more info is needed.
AutoCad Map 3D 2014
Windows 7 Professional 64-bit
Office 2010 64-bit
2 REPLIES 2
Alfred.NESWADBA
in reply to: rsniff
what type of datasources do you use in that drawings? Images, Shapes, SDF's, database-connections (what database) ...?
Have you tried to clear the Map-Cache folder? Maybe there are too many files in it (command _MAPOPTIONS ==> tab System), also check the number of files in your temp folder, clean it too if possible.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
braudpat
in reply to: rsniff
Hello rsniff
Welcome to the Autodesk/AutoCAD Forums !
+1 with Alfred
Other ideas:
- Have you a lot of FDO Labels ?
I am speaking of maybe more than 5000/10000 FDO Labels ... which are using MTExt (Default) and not Text ...
- Have you a lot of complex FDO rules one some heavy FDO layers ?
- Have you installed the SP 1 for MAP 2014 ?
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=22356664&linkID=9240858
Bye, Pat
Patrice ( Supporting Troops ) - Autodesk Expert Elite
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Felicitations) - Thanks
Patrice BRAUD
”Boost
