I am having an issue with certain maps taking a long time to open. There is a window that opens up that says "Stylizing...." and it just sits there not responding. It seems to happen after I connect to external data through Data Connect. Also sometimes after I Mapimport a shapefile. I am inexperienced with Map 3D so please ask me questions if more info is needed.
AutoCad Map 3D 2014
Windows 7 Professional 64-bit
Office 2010 64-bit
what type of datasources do you use in that drawings? Images, Shapes, SDF's, database-connections (what database) ...?
Have you tried to clear the Map-Cache folder? Maybe there are too many files in it (command _MAPOPTIONS ==> tab System), also check the number of files in your temp folder, clean it too if possible.
- alfred -
Hello rsniff
Welcome to the Autodesk/AutoCAD Forums !
+1 with Alfred
Other ideas:
- Have you a lot of FDO Labels ?
I am speaking of maybe more than 5000/10000 FDO Labels ... which are using MTExt (Default) and not Text ...
- Have you a lot of complex FDO rules one some heavy FDO layers ?
- Have you installed the SP 1 for MAP 2014 ?
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=22356664&linkID=9240858
Bye, Pat
Patrice BRAUD
