AutoCAD Map 3D General
Member
Message 1 of 4 (143 Views)
"Relative" Data Connections to SHP files and Databases
143 Views, 3 Replies
09-10-2013 06:59 AM
Is it possible to create a "relative" connection to databases and SHP files in Map 3D, similar to the ability to create a relative external reference to a Civil 3D drawing file?
antoniovinci
Message 2 of 4 (137 Views)
Re: "Relative" Data Connections to SHP files and Databases
09-10-2013 08:03 AM in reply to: jchensley
Did you just try the _MAPCONNECT command..?
Member
Message 3 of 4 (133 Views)
09-10-2013 08:19 AM in reply to: antoniovinci
Yes, I used the MAPCONNECT command. I am able to connect to the data no problem. I think you are misunderstanding my question.
The issue I'm having is that multiple users access this data and work remotely. Most of the time, it is more efficient for them to download the data from our server to their hard drive and then upload them back to our server at the end of the day. The MAPCONNECT command appears to use the "full path" to find the data, such as this:
S:\Project_Files\Example_Project\Drawings\GIS_Data
When they open a drawing file that is connected to GIS data, all of the connections are broken because the filepath has changed. If a "relative path" could be used, it would look like this:
.\GIS_Data
Instead of looking for the GIS data on our server, AutoCAD would look for the folder titled "GIS Data" within the directory of the drawing file they opened. No more problems with broken data connections.
This is the way XREFS (External References) work in AutoCAD. Type the command "XR" to see what I'm talking about if you are not familiar with how xrefs work.
Instead
antoniovinci
Message 4 of 4 (98 Views)
09-11-2013 03:39 AM in reply to: jchensley
Well, it was a true challenge, but... uncompress the attachment where you want.
Sounds like the DWG format isn't able to store a relative FDO path, while the DXF does...
You are not logged in.
Ask the Community
