AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
mapiinsert
2 REPLIES 2
rasterized
1598 Views, 2 Replies
mapiinsert
I'm using AutoCAD Civil 3D 2013 and am wondering if Autodesk has changed how it handles the mapiinsert command?  I've never experienced a problem inserting my local dataset of orthoimagery until now. I've checked my insert and drawing units, as well as the coordinate system.  Am I missing something?
2 REPLIES 2
And the problem now is?
  • AutoCAD crashes
  • does not insert the image
  • gives an error message
  • inserts the image not georeferenced
  • inserts the image georeferences, but wrong coords
And you tried that in new drawings (based in original Civil-templates)?
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at ... blog.hollaus.at ... CDay 2024
(not an Autodesk consultant)
rasterized
in reply to: rasterized
The state plane coord sys reference in the image header is misinterpreted. I think this needs a better fix but to avoid the problem, clear any coordinate system before calling mapiinsert.  It can be reinstated, after all imports with a referenced geodetic system of course.
”Boost
