AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
mapbook template
4 REPLIES 4
projects45
368 Views, 4 Replies
mapbook template
Using map 2012 3D , my mapbook template looks good when I open it up in the template file but when I use it in an existing mapbook the scale is double and is off center. thanks
4 REPLIES 4
braudpat
in reply to: projects45
Hello
1) Have you used a percentage overlap ?
If YES, please could you retry with ZERO to check if you have the same probleme ?
2) Have you installed the SP 2 on your MAP 2012 :
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=19820805&linkID=9240858
Bye, Pat
Patrice ( Supporting Troops ) - Autodesk Expert Elite
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Felicitations) - Thanks
Patrice BRAUD
projects45
in reply to: braudpat
Yes I tries zero overlap and SP 2 is installed. Is there any way I can get the default mapbook template file replaced. Thanks for your help.
braudpat
Hello from France
Sorry I not sure to well understand your question/problem !?
Please look at a good old MAP French Screen capture : you will see where you can select the right MAP DWT ...
But maybe it is not your problem !?
Bye, Pat
PS: the common bug that I know with MAP Atlas Generation 2008-2014 is the scale Factor in each major MVIEW
which is FALSE asap you have used any overlap percentage ...
Patrice BRAUD
projects45
Thanks for the help
”Boost
