AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
level curves
3 REPLIES 3
sergiu.sofronie
2065 Views, 3 Replies
level curves
Hello ... I would like to know if I have a survey study (topographical study) of a terrain with lots of point in 3d coordinates, is there any way to generate the level curves automatically? Thanks
3 REPLIES 3
what version of Map3D do you have?
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at ... blog.hollaus.at ... CDay 2024
(not an Autodesk consultant)
hello ... I have 2012 version x64.
besides that I don't think that points (without breaklines) are enough to create a surface ... you can:
a) use command _MAPCREATESURFACE to create a DEM out of your points
b) after creating the DEM Map3D displays it within the GIS-layer (in MAPWSPACE)
c) right-click on the DEM-GIS-layer ==> and you get the option to create contour-lines
One additional point to that: the precision is limited, I have not found a value to set the grid-size for converting the triangulation to the DEM.
And the option would be to do that with Civil3D, I would prefere it, however I don't know if you have access to it.
Good luck, - alfred -
Alfred NESWADBA
”Boost
