MapGuide will use whatever coordinates you set as the coordinate system;
they can be state planes, UTM, or whatever.
The Report option of the Define Query command can produce a list of X,Y (and
Z) coordinates for objects in a query. Define a query, then select the
Report option; from the Expression area, choose Properties; from the list
select either X coordinate of start point (to get the X value) or Object
Start Point (to get X,Y, and Z).
You can also get a list of things like block name from the same list, or
attribute values from the Data list.
Hope this helps,
David
"amalia" wrote in message
news:7A6326DB01DBF262B59C5F70A4CE1799@in.WebX.maYIadrTaRb...
> Hi,
> I would like to know how to generate a list of lat-lon to be used in
the
> creation of goto view features in mapguide? I believe lat-lon is needed in
> order
> for us to create a goto view in mapguide query. it will be inconvenient to
> manually encode each block(building or parcel) if we have an over a
thousand
> blocks!Thanks in advanced.
> Outgoing mail is certified Virus Free.
> Checked by AVG anti-virus system (http://www.grisoft.com).
> Version: 6.0.313 / Virus Database: 174 - Release Date: 1/2/2002
