AutoCAD Map 3D General
New Member
Message 1 of 9 (239 Views)
labelling 3dpoly vertex
239 Views, 8 Replies
01-15-2008 12:54 AM
I create a 3D polyline and I want to display Z coordinate of any vertex with a text or a label.
I find a way to display Z coordinate of first (X1,Y1,Z1) and last (X2,Y2,Z2) vertex with display options but not for any vertex.
Someone can help me?
Massimo
Distinguished Contributor
Message 2 of 9 (239 Views)
Re: labelling 3dpoly vertex
01-16-2008 01:44 AM in reply to: bming
Hi Massimo,
Enough difficult task to practicing my LISP knowledge (it was better in the past), and to remember my programming days.
I did one LISP program for labeling of 3D poly vertexes. Save somewhere file POLY.LSP and load it in AutoCAD with command APPLOAD. Start it with command LAB.
Hopefully will be useful for you.
Drazen Galic
d.galic@studioars.hr
www.studioars.com
New Member
Message 3 of 9 (239 Views)
01-17-2008 06:53 AM in reply to: bming
Thank you Drazen!
I tried your lisp application and it worked successfully.
Massimo
Member
Message 4 of 9 (162 Views)
06-24-2013 05:08 PM in reply to: bming
I tried this Lisp but the Z values are displayed as 0... what I am doing wrong?
*Expert Elite*
Alfred.NESWADBA
Message 5 of 9 (153 Views)
06-24-2013 11:42 PM in reply to: v.tsamis
for me it's working, if you start _LIST and select one of those objects what Z-values do you get? (or upload the drawing with one or two of the objects you tried).
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at
*Expert Elite*
antoniovinci
Message 6 of 9 (147 Views)
06-25-2013 01:45 AM in reply to: v.tsamis
Perhaps your contours are flattened to ground zero, typical behaviour of digitized topo maps.
Member
Message 7 of 9 (139 Views)
06-25-2013 05:36 AM in reply to: antoniovinci
When I type _LIST I can see all the vertex values(Geomentry X,Y,Z). Why is not showing when I apply the lisp?
I include the polylines (any really) I am trying to have Z values visible on my plan.
*Expert Elite*
Alfred.NESWADBA
Message 8 of 9 (130 Views)
06-25-2013 06:26 AM in reply to: v.tsamis
your drawing has proxy objects and so that tool reports 0 (why ever, I've not looked into the LISP).
You see that this drawing is not clean if you try to use copy/paste to get those polylines to a new drawing. I get then a message that this is not possible because of proxy-objects.
If you create a new drawing, then insert that drawing you have uploaded into the new one (with option "explode") then this tool is able to write the Z-values to the polylines vertizes.
Good luck, - alfred -
Alfred NESWADBA
Member
Message 9 of 9 (119 Views)
06-25-2013 02:42 PM in reply to: Alfred.NESWADBA
Thank you so much... it was as you said. Copy paste to a different drawing and values appear!!
Brilliant
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
