AutoCAD Map 3D General Discussion
Active Contributor
donald.e.clark
Message 1 of 11 (462 Views)
importing GPS points
462 Views, 10 Replies
08-19-2013 02:44 PM
Should I use a csv file to import GPS points or should I set them up in ArcGIS first?
Alfred.NESWADBA
Message 2 of 11 (440 Views)
Re: importing GPS points
08-20-2013 12:12 AM in reply to: donald.e.clark
....to do what?
Sorry, it depends strongly to what do you want to do with that points? So we need to know that to be able to answer this question.
It's also necessary to know how you have your points currently stored (on what device or in what file format).
BTW: what do you mean by "set them up in ArcGIS"?
- alfred -
Alfred NESWADBA
Active Contributor
donald.e.clark
Message 3 of 11 (418 Views)
08-20-2013 08:21 AM in reply to: Alfred.NESWADBA
GPS points are saved as a csv and a dxf.  A different file type can probably be used if needed.
I have power pole points for design and road points for reference.  I would say what I want to do is "Convert Data to Industry Models".
The information is arranged:  point number, X, Y, Z, point description.  I am thinking maybe I need to edit the information in ArcGIS then connect AutoCAD to the database file.
Using AUD with all Map 3D tools enabled.  AUD expert told me that my questions are more so about Map 3D.
antoniovinci
Message 4 of 11 (410 Views)
08-20-2013 11:35 AM in reply to: donald.e.clark
Simply try the _IMPORTPOINTS command, choosing PENZD input format.
Active Contributor
donald.e.clark
Message 5 of 11 (404 Views)
Using GPS points as data, maybe not for importing
08-20-2013 01:17 PM in reply to: antoniovinci
The descriptions for the pole points states the construction status of the pole.  Existing, Install, or Replacement.  Descriptions for Install states Pole Top.  What steps do I need to go through to have the different types of pole status in the Display Manage?
I want to use Attribute Data and Industry Models.  Now I am thinking that "Convert Data to Industry Models" doesn't work for txt or csv files.
Murph
Message 6 of 11 (397 Views)
Re: Using GPS points as data, maybe not for importing
08-20-2013 05:10 PM in reply to: donald.e.clark
Use the Survey Tab of the display manager and create a new data store then import the points. Using the mapimport and txt files will lose some of the data.
Murph
Supportting the troops daily.
Active Contributor
donald.e.clark
Message 7 of 11 (381 Views)
08-21-2013 09:59 AM in reply to: Murph
Points didn't show.  What am I doing wrong?  What file type should I import when using the data store?  Oh, creating the data store does not import the points?
I can xref the dxf of the GPS points but regular AutoCAD has that capability.
What is the best way to use the raw data I have, in AUD (as Map 3D) with Industry Models to create Object Data?  Would there be recommanded data editing before importing it?
There might be several steps that I am planning to do in the wrong order.
antoniovinci
Message 8 of 11 (373 Views)
08-21-2013 11:20 AM in reply to: donald.e.clark
Please share with us your .CSV file, just to cast an eye over it, sir.
Murph
Message 9 of 11 (364 Views)
08-21-2013 04:47 PM in reply to: donald.e.clark
After you create the data store you need to import the points, after that you can style (display) the points as you like, by the attributtes.
Upload a few lines of the cvs file and we'll show you.
Murph
Active Contributor
donald.e.clark
Message 10 of 11 (349 Views)
Task Pane Survey tab, csv is best
08-22-2013 07:21 AM in reply to: Murph
One last issue for this tread:  I do not need point numbers displayed.  I would prefer the point descriptions be displayed instead.
You are not logged in.
Ask the Community
