AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
import points file to map
3 REPLIES 3
422 Views, 3 Replies
Is there an easy way to import a points file to Map.
I have a text file containing Northerly, Easterly and elevation information
and would like to import these points into Map 4. Additionally I would like
to place point objects at each point.
Thanks in advance for your help.
Lee
3 REPLIES 3
Hello Lee
Check out Tony Ts site @ http://www.caddzone.com
Check out his 'Free Stuff' section and there you will find a great lisp
routine: ASCPOINT
which allows the import of an ascii point file.
Hope this helps
Warren M
IMAGINiT Technologies
"Leford" wrote in message
news:166D745F8D4AC2A008F0A28D3DF1D676@in.WebX.maYIadrTaRb...
information
like
> Lee
Hi Leford,
I could send you VBA macro to insert point, block or circle based on txt
coordinat?
Milos
information
like
> Lee
BillGates
Excellink works well for this as well.
-Aaron-
”Boost
