Saved file appears to load aerial image tiles, but after automatic loading of shape files, images no longer visible. I am new user, how do I fix without having to delete and reload image files?
how did you create the DWXF? Have you used the plot command, and if so, did you plot from modelspace or paperspace?
And additional questions:
- alfred -
>> I am loading four aerial TIFF files
How do you load it? What command did you use? (_IMAGE or _MAIINSERT or _MAPCONNECT)
>> but then when the active shape files load, the image files are no longer visible.
And that is not just the draworder, so the shapes are above your images?
>> The Image Management pop-up lists "Visible" as No
What is "Image Management"? Can you upload a screenshot from that as this word is unknown to me (I'm working in German AutoCAD, so it maybe just the wording I can't find a translation for).
- alfred -
