AutoCAD Map 3D General Discussion
Active Contributor
eduardocmoreira
Message 1 of 6 (287 Views)
drainage divide
287 Views, 5 Replies
09-24-2009 03:17 AM
Does anyone know how to get the drainage divide lines from a layer with contour lines?
Should I use Autodesk Civil 3D instead? How can I do it?
Thank you
Active Contributor
kclark138
Message 2 of 6 (287 Views)
Re: drainage divide
09-24-2009 09:40 PM in reply to: eduardocmoreira
Civil 3D with Watersheds. I think it can be done in Map but will take more prep of the data.
Kevin Clark P.E.
www.inmotioncon.com
*Joe Bouza
Message 3 of 6 (287 Views)
Re: drainage divide
09-30-2009 08:56 AM in reply to: eduardocmoreira
Not to be snarky, but I have found it waaaay faster and straight forward to
simple "Read" the contours and place a pline by hand. By the time you finish
muckin' round with Watershed settings et al you would probably have it drawn
in
*Kevin Clark P.E.
Message 4 of 6 (287 Views)
Re: drainage divide
10-01-2009 08:12 PM in reply to: eduardocmoreira
Civil3D watersheds
wrote in message
news:6260075@discussion.autodesk.com...
contour lines?
Thank you
*Joe Bouza
Message 5 of 6 (287 Views)
Re: drainage divide
10-02-2009 05:38 AM in reply to: eduardocmoreira
Hi Kevin, How do you deal with the "drainage notch" and "Flat area"
boundaries created with that? Out Tributary area maps do not typically
included those; (we have a mad scientist that decides where the water wants
to go, for us )
Joe
*David Parker
Message 6 of 6 (287 Views)
Re: drainage divide
10-02-2009 03:27 PM in reply to: eduardocmoreira
Check your shp file resources from states, counties, towns, etc. many have
watershed files available.
dave
"Joe Bouza" wrote in message
news:6264823@discussion.autodesk.com...
to go, for us )
Joe
You are not logged in.
Ask the Community
