AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
display a int32 defined field as a number with comma's
1 REPLY 1
dhoskings
245 Views, 1 Reply
Does anyone have a setup or style expression that will take a field in a shape file that is defined as an integer and display it on a map with comma's for the 1000 maker (ie. 5913240 as 5,913,240).
I am using AutoCAD Map v2012 (can use 2013 if it has anything built in)
1 REPLY 1
phil_borycens
in reply to: dhoskings
Hi there,
As far as I know, the Expression Builder does not allow for that type of formatting for numbers. The only real options there are for formatting the display of data like that are with the Date Formatting Options.
Phil Borycens
”Boost
