AutoCAD Map 3D General
Distinguished Contributor
twiebe
Message 1 of 2 (74 Views)
delete command???
74 Views, 1 Replies
05-11-2004 11:39 AM
For some unknown reason I can no longer select an object and use the delete key to remove it. Also, when I select an object, my layer toolbar on top doesn't change. It remains at what ever it was previously set at.
Thanks for the help,
Tim
twiebe
Message 2 of 2 (74 Views)
Re: delete command???
05-11-2004 11:50 AM in reply to: twiebe
Found the answer! Use the "Pickfirst" command. and select 1 as a value.
Thanks anyways!
You are not logged in.
Announcements
Need installation help?
Ask the Community
