AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
delete command???
1 REPLY 1
twiebe
207 Views, 1 Reply
delete command???
For some unknown reason I can no longer select an object and use the delete key to remove it. Also, when I select an object, my layer toolbar on top doesn't change. It remains at what ever it was previously set at.
Thanks for the help,
Tim
1 REPLY 1
twiebe
in reply to: twiebe
Found the answer! Use the "Pickfirst" command. and select 1 as a value.
Thanks anyways!
”Boost
