AutoCAD Map 3D General Discussion
DiegoP1978
Message 1 of 8 (233 Views)
database
233 Views, 7 Replies
12-18-2012 06:29 AM
Hello everybody,
i'm trying to add a database (excel ) as source for object in Map3D.
i start but when i select the excel file that i've created and stored in my pc map3d says that the cration of the data source doesn't work.
Is anyone able to help me?
thx
Diego
antoniovinci
Message 2 of 8 (223 Views)
Re: database
12-18-2012 09:44 AM in reply to: DiegoP1978
Prima rispondi a questa, una alla volta...
Murph
Message 3 of 8 (206 Views)
Re: database
12-18-2012 03:26 PM in reply to: DiegoP1978
DiegoP1978 wrote:
Hello everybody,
thx
Diego
What version of Map3D and what OS are you using? 32 or 64 bit? Have you created an ODBC connection to the Excel file?
Murph
Supportting the troops daily.
DiegoP1978
Message 4 of 8 (197 Views)
Re: database
12-18-2012 11:24 PM in reply to: Murph
thx for reply.
my Map3D version is 2013. The OS is windows 7 64 bit.
I don't have created an ODBC connection to the Excel file. I'm a rookie for Map3d trying to learn to use it because for my job is important to learn how to use a GIS manage charts and add information or keep information from it.
thx for reply
Diego
antoniovinci
Message 5 of 8 (193 Views)
Re: database
12-19-2012 01:19 AM in reply to: DiegoP1978
In my Map2006, it works according the attached ODBC setup: try with my example DWG/XLS (se non capisci qualcosa, scrivimi in privato).
DiegoP1978
Message 6 of 8 (188 Views)
Re: database
12-19-2012 04:37 AM in reply to: antoniovinci
thx to reply.
I try to set the connection using the files you attached to your previous email. Doesn't work.
The screenshots are a little different maybe for the version and maybe because on my pc i don't have this Microsoft jet 4.0 ole db provider (see screenshot 2)
I attach an exemple of what i try to do.
1. i give a name to the connection
2. i select the  MS ole db provider for odbc drivers ( but i'm not sure it's right)
3. here i can set the source of my db ( Excel file)
4. here i set readwrite
5. here is the resume of the connection
6. After this i lunch the plugin for the connection i browse to the folder where i stored my Excel file but here appears this warning.
thx
Diego
Murph
Message 7 of 8 (172 Views)
Re: database
12-20-2012 03:09 PM in reply to: DiegoP1978
DiegoP1978
Message 8 of 8 (166 Views)
Re: database
12-20-2012 11:23 PM in reply to: Murph
Hello everybody.
Thank you for your help.
I understand that is a problem of drivers.
I make a research on web and i see that now there is a new driver for windows 7 64bit and i will soon try to install it and to use it to import excel files into map3d.
I'll post news very soon.
Thank to all that give me help.
Good last day on earth...
Bye
You are not logged in.
Ask the Community
