I am trying to create links using object data. I want the data to go into a
table in SQL Server 2000.
I create the links and a table is created in SQL Server. I am able to see
and edit the table data in AutoCad.
The Problem: The link template says the 'database is not connected or
attached'. This happens even if I Detached/Attached the database or if I
disconnect/connect or if I close and reopen the file.
Any help is greatly appreciated!
Renee
