I have a property "chaney_dell|Comments" from a joined database and I would like to use an expression like:
concat( "chaney_dell|Comments" ,'\P\', Tract_ID ,'\P', owner ,'\P', acres, ' ACRES' ,'\P', 'S-', sec ,' T-', twn ,' R-', rng ,'\P', book ,'/', page )
All I get is "text" as a label for my shape and when I go back to edit the expression it adds quotation marks to the beginning and end.
"concat( "chaney_dell|Comments" ,'\P\', Tract_ID ,'\P', owner ,'\P', acres, ' ACRES' ,'\P', 'S-', sec ,' T-', twn ,' R-', rng ,'\P', book ,'/', page )"
If I take the quotation marks off of chaney_dell|Comments it will not validate because of the | character. What am I missing here?
I took it out but it still gets hung up on the | character. If I ever get this figured out the second \ would have definietly given me problems, thanks!
OK had a few moments to "Play" and I'm getting the same result. I'd say if you're on subscription open a support request and give it a higher priority, or take your chances to see if Nate & his fellow gurus respond here... 😞
| is an "illegal character"?
do a calc and title the column without the |
for the calc select the property with the bar & OK. The data should be identical in both columns. Use the new column in the concat
Dave
Problem I found was that, at least in my C3D R2012 install, when I tried to style with an expression based on an expression and used "concat" then selected the field from the pull-down, a new line, and a piece of static text, I still just got "text" as the resulting label - not what I expected at all....
which is caused by the | in the joined column heading. I've had the same problem and solved it two ways, one as I explained and the other is mapimport and mapexport which changes the column from a join to part of the OD. One of the shortcomings of Map3d i guess.
Concur - it's funny that it would happen with an element put there by the software and not the user. seems par for the course with what we're given - "why use one step when 3 to 5+ just might get you there..."
When I try to do the calc that property does not show up? I have a data connection with a shp file and an ODBC excel file. When I view the table and go to create a calculation it only shows the shp file properties not the ODBC properties.
