Hi Paul,
Here's the procedure.
Open a new DWG, attach the DWG with the contours, define a query to import
all the data, set Query Mode to Draw. Now you use Property Alteration to
change the elevation: this lets you change the properties of data as you
query it into the DWG. To move your points to the right elevation, you use
Property Alteration to change the Elevation, select Elevation, click on the
Data button near the foot of
the dialog box, choose the Elevation attribute, choose OK, then choose Add.
Choose OK and then Execute the query. Your data should come in at the
correct
elevation.
Let me know if you need more help.
Cheers,
David Walsh
"Paul M"
wrote in message
news:D925F122262DD349AC50560D5B5E117E@in.WebX.maYIadrTaRb...
> Hi,
> I am not a regular user of Map but I am proficient in AutoDesk LDT, Civil
> and Survey.
> My question is this:
> I have a city contour plan which was 'Mapimported' into an AutoCAD dwg
> format. Each new contour pline contains no Zed value, however I have
found
> that when I pick a contour pline using the 'Edit Object Data' feature in
> Map, each pline has the elevation showing in the 'Object Data Field'.
> ...Hope I am making some sense to you Map users.
> Is there a way to automatically assign the Object Data Field 'Elevation'
to
> the Zed of the ACAD pline entity?
