AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
block attribute
1 REPLY 1
GhyslainBaril2008
315 Views, 1 Reply
block attribute
I have a block content many attribute.  When I'm create the block whit this many attribute, the order of this attribute is not properly.  I know autocad have a command to class this many attribute in order but i search it and i don't know where is it... you have way to helps me
Thanks a lot
1 REPLY 1
The order is based on the oder you select the attibutte tags when you create the blocks. To reset the order use the BATTMAN command and be sure to SYNC after you reorder them.
Murph
Supporting the troops daily.
”Boost
