I have a block content many attribute. When I'm create the block whit this many attribute, the order of this attribute is not properly. I know autocad have a command to class this many attribute in order but i search it and i don't know where is it... you have way to helps me
Thanks a lot
Solved by Murph_Map. Go to Solution.
The order is based on the oder you select the attibutte tags when you create the blocks. To reset the order use the BATTMAN command and be sure to SYNC after you reorder them.
