AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
blacked out view ports?
6 REPLIES 6
336 Views, 6 Replies
I have AutoCAD map 3D 2011.
My layout background is white, and sometimes the viewport(s) appear blacked out. I can plot fine, no problems there. It makes it hard to see what I have in my view port. I have removed the viewport and created a new one that will fix the problem approx. 50% of the time.
What causes this? Does anyone know?
6 REPLIES 6
Alfred.NESWADBA
I have not seen something like that, so I can only guess ...
  • graphiccard or driver
  • hardware accelerationon/off
  • wrong scaling of the vierport compared to think objects like e.g. polylines with width or hatches of type solid
  • command REGENALL necessary
If you have such a drawing, what happens when you close it and reopen it? If the problem persists can you upload such a drawing then?
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at ... blog.hollaus.at ... CDay 2024
(not an Autodesk consultant)
in reply to: Alfred.NESWADBA
Thanks for the reply.
I don;t think it's the graphics card or drivers because it only happens every great once in a while.
like now I'm working on a project that has 78 sheets each steet has at least 2 view ports and I only have one that is having this problem. I have created a new layout and the proble move to another sheet. I do not want to have to redo all the sheets.
scaling is OK I've checked, and the sheets print out at the right scale.
regen does not help.
I'm lost!!
Alfred.NESWADBA
Hows the variable MAXACTVP set? (Details look >>>here<<<)
- alfred -
Alfred NESWADBA
My MAXACTVP is set to 64 and the vport is turned on.
Alfred.NESWADBA
HI,
have you tried to raise this value? I know that the help says "per layout" but I would try that to be sure 😉
- alfred -
Alfred NESWADBA
The setting is set to the max number of view ports.
”Boost
