AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
bing in wrong place.
2 REPLIES 2
alexkonieczka
567 Views, 2 Replies
i set my cs to fl83-ef and pulled in roads and parcels.
when in attach bing it automatically assigns the wgs84 p m coordinate system and is uneditable but the map is about 70 miles to the right.
is there some setting i am missing? thanks, alex
2 REPLIES 2
nevermind. the cs for my county is supposed to be fl83-ef and it said that in the prj file. but the new shape file was done in fl83-wf.  the bing image was in the right place after all.
Sounds like a mismatch between your CRS (i.e. EPSG:2236 in feet) and the Bing one (i.e. EPSG:3857 in meters), so try conversely: first attach the Bing imagery, then _MAPIMPORT the shapefile with on-the-fly CRS conversion.
”Boost
