I also get the ade.arx ARX Command error. It concerns Autodesk Map 2004. Here at work we use the Network Deployment tool provided on the Autodesk Map CD's. I successfully created a deployment which to my knowledge worked fine. Now when I deploy Autodesk Map 2004 it completes successfully. I checked this also in the log file on the server (where the install dir. resides). Then when Autodesk Map starts under a standard domain user account it hangs at "Initializing" and returns this error: "Unhandled Exception c0000005 (Access Violoation Writing 0x0004) at address 7C01054Bh." The title of this error message is "C:\location of Autodesk Map 2004 ade.arx ARX Command".
I also tried KB http://usa.autodesk.com/adsk/servlet/ps/item?siteID=123112&id=2887222&linkID=2475323. That didn't work because the MDAC are already installed. Reinstalling doesn't work either.
Please help me out.
With kind regards,
Dereck Breuning
Message was edited by: DBreuning
