AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Zoom Extents problem
1 REPLY 1
rholyn
449 Views, 1 Reply
When I use Zoom Extents, my map becomes a tiny dot near the edge of model space. This happens will all of my drawings and they are not "zooming" to the same area in model space. One might be a tiny dot hidden in the left corner under the geomarker and the next might be in the upper right corner 1/4" in size. Any suggestions?
1 REPLY 1
parkr4st
in reply to: rholyn
you have some object(s) in those extreme corners.  ctrl a  and ctrl1   what are the properties?  esc and try selecting each area until you locate what is there
”Boost
