When I use Zoom Extents, my map becomes a tiny dot near the edge of model space. This happens will all of my drawings and they are not "zooming" to the same area in model space. One might be a tiny dot hidden in the left corner under the geomarker and the next might be in the upper right corner 1/4" in size. Any suggestions?
you have some object(s) in those extreme corners. ctrl a and ctrl1 what are the properties? esc and try selecting each area until you locate what is there
