AutoCAD Map 3D General Discussion
Active Contributor
Ronaldo54
Message 1 of 9 (520 Views)
Xref Edit
520 Views, 8 Replies
08-19-2010 07:47 PM
When I try to edit a particular Xref in a drawing, I get a message saying:-
Selected Xref Block is NOT editable.
Is there a setting somewhere that controls this?
Cheers
*Expert Elite*
Murph
Message 2 of 9 (511 Views)
Re: Xref Edit
08-20-2010 06:16 AM in reply to: Ronaldo54
Could be the xref file is set as read only.
Murph
Supportting the troops daily.
Active Contributor
Ronaldo54
Message 3 of 9 (495 Views)
Re: Xref Edit
08-22-2010 04:30 PM in reply to: Murph
Thanks for your reply Murph.
The Xref file is not read only, so that is not the problem.
Anyone have any other suggestions?
Member
vette94
Message 4 of 9 (109 Views)
Re: Xref Edit
06-25-2013 03:29 PM in reply to: Ronaldo54
I'm having the same problem. I find that an xref in paper space is editable, however one in model space is not.
*Expert Elite*
Murph
Message 5 of 9 (103 Views)
Re: Xref Edit
06-25-2013 04:53 PM in reply to: vette94
What command are you using to edit it and what version?
Murph
Member
vette94
Message 6 of 9 (94 Views)
Re: Xref Edit
06-26-2013 07:02 AM in reply to: Murph
I am using 2013-LT. I have tried double clicking the image, and have also
tried using the edit tool. No luck.
*Expert Elite*
Murph
Message 7 of 9 (82 Views)
Re: Xref Edit
06-26-2013 04:46 PM in reply to: vette94
Image as in a jpg or bmp? or is it a dwg that is xreferenced into your dwg? Is the one in modle space the same as the one in paper space?
Murph
Member
vette94
Message 8 of 9 (77 Views)
Re: Xref Edit
06-27-2013 06:04 AM in reply to: Murph
It's a dwg xref'd into model space and viewed through a viewport in paper
space. I've tried editing through the vport and, changing to model space
and editing. No luck.
*Expert Elite*
Murph
Message 9 of 9 (71 Views)
Re: Xref Edit
06-27-2013 04:09 PM in reply to: vette94
Is the layer for the xref lock in the viewport?
Murph
You are not logged in.
Announcements
Need installation help?
Ask the Community
