AutoCAD Map 3D General Discussion
Valued Contributor
Neil47
Message 1 of 19 (1,234 Views)
World Files Not Recognised
1234 Views, 18 Replies
06-18-2012 03:21 AM
I am trying to insert Geo-referenced TIF files into Map 2013 but the associated World files are not being found/recognised even though they are in the same directory as the image. I have tried both TAB and TFW using MAPIINSERTand Data Connect.
Going back to Map 2012, which we still have in the office, the World files are found and correlated correctly with both of the above World file types and Map commands.
I can do what I need to do in 2012 for the moment but has anyone else had this problem?
antoniovinci
Message 2 of 19 (1,231 Views)
Re: World Files Not Recognised
06-18-2012 04:05 AM in reply to: Neil47
Try to embed the .TFW file in the header of your .TIF, by means of the free GeoTiffExaminer tool, sir.
Valued Contributor
Neil47
Message 3 of 19 (1,200 Views)
06-19-2012 03:29 AM in reply to: antoniovinci
Thanks for the tip, it's a nice tool and has provided a work round for the problem I'm having although I'd still like to know why Map was not finding the world files.
antoniovinci
Message 4 of 19 (1,194 Views)
06-19-2012 05:30 AM in reply to: Neil47
Feel free to paste here the content of that Worldfile, thanx.
Valued Contributor
Neil47
Message 5 of 19 (1,176 Views)
06-20-2012 12:21 AM in reply to: antoniovinci
As noted in my first post these are both found and used by Map 2012 to locate the raster file correctly but not by Map 2013 - hopefully thwe layout of the contents isn't lost in the formatting of the post
Contents of TFW file are
1.000000000000000
0.000000000000000
0.000000000000000
-1.000000000000000
335000.500000000000000
134999.500000000000000
And contents of TAB file are
!table
!version 300
!charset WindowsLatin1
Definition Table
  File "ST33SE.TIF"
  Type "RASTER"
  (335000,130000) (0,5000) Label "Pt 1",
  (340000,130000) (5000,5000) Label "Pt 2",
  (340000,135000) (5000,0) Label "Pt 3",
  (335000,135000) (0,0) Label "Pt 4"
  CoordSys Earth Projection 8, 79, "m", -2, 49, 0.9996012717, 400000, -100000
  Units "m"
antoniovinci
Message 6 of 19 (1,174 Views)
06-20-2012 02:18 AM in reply to: Neil47
Are you REALLY sure that .TFW file name is ST33SE like its own TIFF ?
If so, erase or move the original .TFW anywhere, then with GeoTiffExaminer recreate it from the Geotiff already existing, and try again in Map2013.
New Member
alberto00
Message 7 of 19 (1,132 Views)
08-23-2012 04:42 AM in reply to: Neil47
The same thing happened to mee too...
Georeferended .tif image in the right position with civil 3d 2012. .tfw file not recognized in civil 3d 2013....
Member
andreas.kluser
Message 8 of 19 (834 Views)
06-23-2013 11:02 AM in reply to: Neil47
Same thing happened to me too with Civil 3D 2013.
My problem was that the path to the *.tif and *.tfw was too long (or spaces ...). Putting the two files to c:\temp\ solved the problem.
Active Contributor
surveyor8120
Message 9 of 19 (780 Views)
07-10-2013 03:51 PM in reply to: Neil47
I am having the same problem with Civil3D 2013.
If i change the coordinate system of my drawing to no projection no datum, it will come in just fine.  However if i do not it will come in the wrong place.
I have an geotiff that is in Alaska Stateplane zone 7 (NAD83)  and my current drawing is a custom coordinate system with defined values in Autocadd.
I normally in the past would just edit the world file to make the geotiff come in my drawing in the correct place.  However when I do this it will not work, put it in wrong place.  I notice on the insertion that the correlation data is different than my world file.
 If i change my coordinate system to no datum no projection it will come in to the correct place and the correlation data on the import is same as my world file.
So looks like to me that it is trying to convert on the import.
So what should i do, is there a setting I need to change in Civil 3d / Map?
Anthony Robinson
arobinson@crweng.com
Anthony Robinson, PLS, CFEDS
CRW Engineering Group, LLC
Civil 3D 2013
Windows 7 Prof. x64 SP1
Dell Workstation
Intel(R) Core(TM) i7 CPU
870 @ 2.93GHz
16.00 GB RAM
Active Contributor
surveyor8120
Message 10 of 19 (778 Views)
07-10-2013 04:19 PM in reply to: surveyor8120
I opened my image in a photo viewer then saved as a regular tiff and now Civil3d 2013 will now read the world file and bring it in correct location.
So seems to me that Civil3d 2013 is trying to read my image info instead of world file info?  Which is not the order it is supposed to.  What do you guys think?
Anthony Robinson
arobinson@crewng.com
Civil 3D 2013
Dell Workstation
870 @ 2.93GHz
16.00 GB RAM
You are not logged in.
Ask the Community
