AutoCAD Map 3D General
Active Contributor
Message 1 of 9 (888 Views)
Workspace in Map 3D 2013
888 Views, 8 Replies
10-08-2012 11:53 PM
I have set up my workspace as i like it, & saved it as 2013, then ticked it as current.
When i close then open Map 3D 2013, the workspace has switched to planning & analysis
workspace, which has mysteriously become ticked.
Can anyone help please, thanks in advance
Distinguished Contributor
bingeomatics
Message 2 of 9 (881 Views)
Re: Workspace in Map 3D 2013
10-09-2012 02:15 AM in reply to: Ronaldo54
You must change in "Workspace settings" Switching parameter to "Automatically save workspace changes"
Binnat Khalilov
Active Contributor
Message 3 of 9 (859 Views)
10-09-2012 03:45 PM in reply to: bingeomatics
Yeah, I've done all that, still does not save when I close then reopen ACAD!!!!
bingeomatics
Message 4 of 9 (853 Views)
10-09-2012 11:58 PM in reply to: Ronaldo54
Then attempt to open "Customize User Inteface" window and there on the workspace style which you want right click and set "Set current".
Binnat Khalilov
Active Contributor
Message 5 of 9 (788 Views)
10-15-2012 05:32 PM in reply to: bingeomatics
Hasn't worked either, but thanks anyway. Don't know why they make things so difficult!!!!
Product Support
Message 6 of 9 (778 Views)
10-16-2012 06:41 AM in reply to: Ronaldo54
In 2012 this was quite common.  If you still can't get it to stay as set, the startup switch options here might help: http://gisexchange.typepad.com/blog/2011/05/map-2012-default-workspaces.html (also be sure that you have all the updates applied).
Nate Moore, GISP
Geospatial Premium Support Specialist
Global Services
Autodesk, Sarl
Active Contributor
Message 7 of 9 (759 Views)
10-16-2012 03:53 PM in reply to: NateMoore
thanks nate,
i have tried everything and still no good.
i will have to put up with it i think!!!!!
Alfred.NESWADBA
Message 8 of 9 (749 Views)
10-17-2012 01:44 AM in reply to: Ronaldo54
Also the answer(s) in >>>the other thread<<< you started ....?
- alfred -
Alfred NESWADBA
pwned555
Message 9 of 9 (329 Views)
06-21-2013 08:39 AM in reply to: Ronaldo54
Is this a known bug that they are working on?  I have the exact same problem, it will not remember the current workspace like it's supposed to.  Instead it resets to the default one constantly.  This normally wouldn't be a huge issue, as you could just change your profile to the default in cui, but we have multiple users sharing one profile and creating their own custom workspaces.  The way it worked in 2011 Map 3D was that once they set theirs to current it would load it instead of the default everytime AutoCAD was opened (and I believe this is how it is supposed to function).
You are not logged in.
Ask the Community
