AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Which table is attached ?
7 REPLIES 7
Message 1 of 8
371 Views, 7 Replies
Hi all,
I am having some 10 entities and 4 object data tables.
These 10 entities are attached different tables. How to Find
out the attached table name in each entity?
Any Help by using VBA?
viswanathan.s
7 REPLIES 7
Message 2 of 8
If you pick the obect and open Properties there is a section for OD: and the name of the table.
Is this what you need?
Jeremiah
Message 3 of 8
Thanks for the reply. I think i am working very old version of
AutoCAD MAP. I am working with AutoCADMAP 2000i.
Which version you are using?
viswanathan.s
Message 4 of 8
Ah yes. I am in Map 2006. In 2000i you will need to go to:
Map menu>> Object Data>> Edit Object Data...
Then select the object you want to see object data for
This will bring up a screen with the table name and all of the data, and it is editable so be careful.
Jeremiah
Message was edited by: JEREMIAHM Message was edited by: JEREMIAHM
Message 5 of 8
HI,
I know this manual method very well. By using VBA how to
find which table is attached to which entity? Simply saying i
will clcik the entity it should show the attached table name.
That's all.
Any help by using VBA?
viswanathan.s
Message 6 of 8
Sorry, dont know any VBA
Jeremiah
Message 7 of 8
Look at at the MapSample.dvb which comes with Map - there's sample code in there that will return OD info for an entity.
Scott
Message 8 of 8
Thanks Scott,
By using mapsample also i am not getting the satisfaction.
There also i need to select the correct tablename from the
combo box and i need to click the correct entity.
But Here i will just click one entity. It should show the
attached table. just one message box is enough.
For your reference 'ADEEDITDATA' command will show any
attached table data. How it is working?
Any help By using VBA?
viswanathan.s
