I have a whack of users on whose computers I need to set up a drive alias. I'd ather not go to each one, fire up Map, then go through the motions of defining the same alias for everyone?
Is there a registry key that gets set? I could then create a REG file and simply run it on everyone's machines.
Or a file that gets changed that I could copy to the users' machines?
Something else I can do?
Thanks for the help.
Solved by Alfred.NESWADBA. Go to Solution.
Find the file ACADMAP.INI
For Win7 and Map3D2013 stored in: C:\ProgramData\Autodesk\AutoCAD Map 3D 2013\R19.0
- alfred -
You da man Alfred, thanks.
sir,
i am a automobile engineer,i am confused what autocad software i should expertise in begining..Autocad or Autocad Alias
please respind to me ,,and i don't have a Graphic card in my PC
No graphic card, no party, sir.
You'd better call your nearest Autodesk reseller, man.
Your question is very different from the initial subject of this thread, please create a new thread instead og hijacking another.
Try here and see if it helps on starting a new thread. http://forums.autodesk.com/t5/Getting-Started-with-the/tkb-p/gettingstarted
