AutoCAD Map 3D General
Member
algete
Message 1 of 7 (112 Views)
When starting autocad map 2010 I get an error
112 Views, 6 Replies
09-23-2013 04:22 AM
Unable to run autocad it could be due to one of the following reasons
This version of AutoCAD was not installed properly
does not have the rights to run autocad
and then get this error:
Fatal Error: Unhandled Access Violation Reading 0x3533760 Exception at 519aeeh
*Expert Elite*
Alfred.NESWADBA
Message 2 of 7 (90 Views)
Re: When starting autocad map 2010 I get an error
09-23-2013 09:35 AM in reply to: algete
welcome @forums.autodesk.com !
As it tells you that one of the possible reasons might be "not installed properly" have you tried to run a repair-install or re-install?
Did Map3D already run on your system or have you installed it now (and so with other words it never run)?
What happens if you login to your system with another Windows user account, does Map3D then start?
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at
Member
algete
Message 3 of 7 (66 Views)
09-23-2013 10:10 PM in reply to: Alfred.NESWADBA
Hello Good morning, it happens with any user both administrator and normal user.
desisntalado and repaired I've tried both and nothing is coming out the same error.
3y servipack I have installed the Microsoft Net Framework 4
Thank you very much for helping
*Expert Elite*
Alfred.NESWADBA
Message 4 of 7 (59 Views)
09-23-2013 10:41 PM in reply to: algete
was Map3D ever running on that system?
What operating system do you have? (and other system specs).
For release 2010 it's more important that Framework 3.5 is installed (and repaired if necessary).
You might also try to start AutoCAD without hardware acceleration (look to the start-parameter /nohardware >>>here<<<) to make it more independent from specific graphiccard driver/version
- alfred -
Alfred NESWADBA
Member
algete
Message 5 of 7 (54 Views)
09-23-2013 11:13 PM in reply to: Alfred.NESWADBA
Hi I have the operating system is Windows XP Professional Servipack 3 3.25 GB of Ram Intel Core 2 Duo   and the program is the AUTOCAD MAP 3D 2010 thank you very much
Member
algete
Message 6 of 7 (52 Views)
09-23-2013 11:15 PM in reply to: Alfred.NESWADBA
I've tried running with / NOHARDWARE and get the same error
*Expert Elite*
Alfred.NESWADBA
Message 7 of 7 (43 Views)
09-23-2013 11:33 PM in reply to: Alfred.NESWADBA
...was Map3D ever running on that system?
- alfred -
Alfred NESWADBA
You are not logged in.
Announcements
Need installation help?
Ask the Community
