AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Weird instruction showing up in Map 3D tutorial page...see attached screenshot!
4 REPLIES 4
rpasser
326 Views, 4 Replies
I'm a GIS user new to AutoCAD Map 3D, and I've been going through the tutorials. I was going through the Manage Data tutorial learning about SDF's, and all the sudden #3:
  1. yada
  2. yada yada
  3. celar the chock box for layer 0.
Huh? Am I missing something here...am I just a n00b? What is this? I am so confused. My gut tells me someone screwed something up with this text because the 'celar' is not capitalized unlike the rest of the instructions. Anyway, I'll contextually figure out the rest of the tutorial but I'm just curious what this is.
4 REPLIES 4
SLHayman
in reply to: rpasser
Most Likely means - Clear the Check box For Layer 0.
hence_the_name
you are probably just a n00b.
http://raumpatrouille3d.blogspot.ch/
parkr4st
in reply to: hence_the_name
Both are right:)
Sometime a little imagination goes a long way with using AD tutorials
The reason to uncheck Layer 0 is so that any objects on Layer 0 are not included in the SDF file.
dave
rpasser
probably. seems whoever made this tutorial was a little too laid-back Cat Embarassed
”Boost
