AutoCAD Map 3D General
Active Contributor
Message 1 of 12 (690 Views)
Accepted Solution
VP Freeze for Display Manager items
690 Views, 11 Replies
10-29-2012 10:14 AM
I created a drawing with multiple layout tabs, so as to create different maps. My display manager consists of data connections & layers added from the Layer Properties Manager. When I activate a viewport from the layout, I want to freeze some of the Data Connection items (like shp files). How can I freeze these items within the active viewport only?
Robyn
*Expert Elite*
Alfred.NESWADBA
Message 2 of 12 (688 Views)
Re: VP Freeze for Display Manager items
10-29-2012 10:24 AM in reply to: rckohler
what version of Map3D do you have?
IMHO you need Map3D 2013 to be able to display different map's per viewport.
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at
Active Contributor
Message 3 of 12 (686 Views)
10-29-2012 10:33 AM in reply to: Alfred.NESWADBA
I'm using 2013.
*Expert Elite*
Alfred.NESWADBA
Message 4 of 12 (680 Views)
10-29-2012 10:54 AM in reply to: rckohler
then you can create mulitple maps (within the dialog _MAPWSPACE) having different stylization or on/off settings of datasources.
And when you have created a viewport you can use command _MAPASSOCVPWITHMAP to assign a map-config to a viewport. If you haven't disabled ribbons you just have to change to the paperspace of a layout to get the context-sensitive-ribbon for layout-tools ==> and there are the icons for assigning maps/legends/scalebars to viewports.
Also look to some videos "what' new in Map3D 2013"
- alfred -
Alfred NESWADBA
Active Contributor
Message 5 of 12 (673 Views)
10-29-2012 02:31 PM in reply to: Alfred.NESWADBA
I created a new display map in model space, then used the suggested command 'MAPASSOCVPWITHMAP' to update my viewport accordingly. This seems to have worked just fine. Now I need to adjust to the thought process of Map 3D versus AutoCAD. I was very comfortable using 'VP FREEZE' in AutoCAD. So i'm basically doing the same thing in Map 3D, just in model space, verses in the layout...
I think I understand that now, please correct me if I've misunderstood, or am going in the wrong direction.
Robyn
*Expert Elite*
Alfred.NESWADBA
Message 6 of 12 (669 Views)
10-29-2012 02:40 PM in reply to: rckohler
you are at the correct way! For all FDO-objects (connected gis-datasources) you have to use the different map-settings to have the aibility for different viewport-visualisation/stylization.
For the plain AutoCAD geometry like mpolygons, polylines, lines, blocks, etc you can use either the viewport-depending freeze or you can also use the map-functionality for stylize these objects (as long as they are selectable by rules). So in this case you can use two different ways to work.
HTH, - alfred -
Alfred NESWADBA
Active Contributor
Message 7 of 12 (667 Views)
10-29-2012 03:09 PM in reply to: Alfred.NESWADBA
Yes, I understand now. Thanks again Alfred!
Message 8 of 12 (652 Views)
10-30-2012 01:02 PM in reply to: rckohler
Seems like it would have been easier just to use this:
Active Contributor
Message 9 of 12 (623 Views)
11-05-2012 11:46 AM in reply to: rckohler
Yes, it sure would. Thanks!
Active Contributor
Message 10 of 12 (537 Views)
11-29-2012 06:54 AM in reply to: tjmapper
The Layer Visibility isn't selectable under the Layout Tools tab. It displays grayed out, as your image clip indicates. How is this activated?
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Need installation help?
Ask the Community
