AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Use table object to display linked table
1 REPLY 1
Neilw_05
431 Views, 1 Reply
I am wanting to use an Autocad table object to display fields from an Access database table that is linked to symbols in my drawing.
My objective is create a database table that has detailed notes for call outs in my drawings and then link my call out blocks to the database table and display the blocks and linked descriptions in an Autocad table. If the notes in the database table are edited the Autocad table updates with the new the description from the database.
Neil Wilson (a.k.a. neilw)
AEC Collection/C3D 2024, LDT 2004, Power Civil v8i SS1
WIN 10 64 PRO
http://www.sec-landmgt.com
1 REPLY 1
nwray
in reply to: Neilw_05
Hi Neil,
I have not yet come across a way to do this with access, but if you use the "table" command, you have the option to use a link to an external Excel table.  I can't test this, unfortunately, because I don't have Excel loaded locally, and it won;t let you do anything without that.
As a work around, I believe that you can export an Access Table to an Excel format, and then use the excel table as a data link and make an AutoCAD table based on that link.
Hope that helps.
Norm
GIS Specialist
BOXX Technologies APEXX 2 2402 Workstation
Intel Core i7-6700K @ 4.4 GHz
32 GB RAM / 500 GB SSD
NVIDIA Quadro M2000 Graphics
Windows 7 Pro 64 bit C3D 2017
”Boost
