AutoCAD Map 3D General
JamaL9722060
Message 1 of 6 (297 Views)
Turning on\off a shape files layer on viewport,
297 Views, 5 Replies
11-29-2013 10:27 AM
I couldn’t figure out why turning off a shape file layer in a particular viewport (attached) does turn it off in all other viewports
Thank you
Best
Jamal
Jamal NUMAN, GIS and Civil Engineer, MSc
e-mail: JamaL9722060@yahoo.com
P.O.Box: 731, Ramallah, West Bank, Palestine.
Software: AutoCAD 2014, AutoCAD C3D, AutoCAD M3D, Revit
Windows 7 (Ultimate 64 bits),
Firefox 20.0,
Kaspersky 2013.
Alfred.NESWADBA
Message 2 of 6 (296 Views)
Re: Turning on\off a shape files layer on viewport,
11-29-2013 10:37 AM in reply to: JamaL9722060
you can create different maps in the mapwspace (or use command _MAPNEWMAP), each of the maps may hold/show the same content or, like you want, in map1 show the shape and in map2 don't show it.
The next step is to assign map1 to viewport1 and map2 to viewport2 (using command _MAPASSOCVPWITHMAP), you get the ribbons with that functionality at the moment you switch to the layout (and you have a map-menu/workspace active).
- alfred -
Alfred NESWADBA
JamaL9722060
Message 3 of 6 (287 Views)
11-29-2013 12:00 PM in reply to: Alfred.NESWADBA
Many thanks Alfred for the help,
Then everything is controlled by “maps” (attached). The issue now that I have no idea how to control maps
1. Rename\delete
2. Copy a layer (or multiple layers) from a map to another
Best
Jamal
Firefox 20.0,
Kaspersky 2013.
Alfred.NESWADBA
Message 4 of 6 (284 Views)
11-29-2013 12:09 PM in reply to: JamaL9722060
Start command _MAPWSPACE to get the dialog for the main AutoCAD Map functionality:
Besides of the possibility to duplicate a map (so you have all the stylizations you already created for one map again in the new map) you always can save a gis-layer with right-click on the layer-name in the mapwspace-dialog, save it as .layer file, then drag and drop this .layer file to any other map you like to see it. That duplicates all the settings/stylizations you already set.
- alfred -
Alfred NESWADBA
Murph
Message 5 of 6 (255 Views)
11-30-2013 05:35 AM in reply to: JamaL9722060
1. Rename\delete
Best
Jamal
The intent on using the Maps verse vieports/layouts that you would use in C3D or vanila AutoCAD is you can style and display the features as you need then open those maps as needed to display and plot. If you create mulitple layouts and try to use viewport overrides for autoCAD layers on the features it doesn't work. Instead we use the "MAPS" instead of layouts for displaying the same data/features  different ways.
Murph
Supportting the troops daily.
JamaL9722060
Message 6 of 6 (240 Views)
11-30-2013 10:35 AM in reply to: Alfred.NESWADBA
Thanks Alfred and Murph for the help. It works fine (attached).
Very much appreciated
Best
Jamal
Firefox 20.0,
Kaspersky 2013.
You are not logged in.
Ask the Community
