AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Troubleshooting Mapbook
1 REPLY 1
312 Views, 1 Reply
I am using Civil 3D 2013 SP1 and I am trying to create a mapbook. I have attached XREFs in model space and I have created a template with the appropriate map placeholders. Here are my settings for "create map book"
Source: Model Space
Sheet Template: My template with a scale of 40
Tiling Scheme: By Area
Naming Scheme: Columns and Rows
Key: None
Legend: None
Sheet Set: Create New
Mapbook creates the tiles and associated layouts. The polylines representing the tiles are in the correct orientation and coordinates. The layout viewport it creates does not match up to the locations it uses in Modelspace and the scale does not match the settings in the setup or of the viewport of the template.
What causes this? I can't seem to find this specific problem in any of the previous posts.
1 REPLY 1
mhvam06
Did you find a solution to this? I have the same problem.
My layout is offset exactly 5 pages to the right and 5 pages north. I have no idea what causes this.
Any help is much appreciated!
”Boost
