AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Transformation grid
1 REPLY 1
minerdetails
547 Views, 1 Reply
Transformation grid
I have a client who is working on the edge of a MGA coordinate zone - as they are near the edge of the zone their scale factor is large and needs to be factored in to all setouts (it makes 50mm of difference over 100 metres.)
their previous solution has been to work day to day at 1 to 1 scale and then xreference this back into a MGA projection by using a scale factor around a single point false origin.
As they are moving away from this false origin - the scale factor is changing slightly.
Is it possible to create a user grid at 1 to 1 for the day to day use and then query this into a MGA drawing. via ADEQUERY to bring it back to MGA ?
Tags (2)
1 REPLY 1
lim.wendy
in reply to: minerdetails
Hi!
May I know which version of Map3D are you using?
You can create a ‘user defined coordinate system’ based on
the zone you are working – and then set the scale reduction factor to 1.
When ADE-querying such a DWG in, the coordinates are
re-projected into the target coordinate system that the host-DWG is using.
Smiley Happy
Wendy Lim
Data Nerd | Community Advocate | AEC Industry
facebook twitter twitter blogs pm
Join the new online Rail Community
Customer Value Hub
”Boost
