AutoCAD Map 3D General Discussion
Active Contributor
torentrue
Message 1 of 6 (385 Views)
Transfer Link Data to Object Data
385 Views, 5 Replies
03-28-2013 01:46 PM
I have a drawing with Objects that have both Object Data and Linked data in an Access database. I need to get information from the linked table to a new linked table for each object.
I have thought that if I get the necessary information from the Linked table record to the object data for each object, I could then convert the Object data to a new link and am looking for a way to copy the data from a field in the Linked Table to the object data.  There is at least one field common to both the OD and Linked Table record.
Is there any automated way to transfer this data?
antoniovinci
Message 2 of 6 (375 Views)
Re: Transfer Link Data to Object Data
03-28-2013 02:55 PM in reply to: torentrue
Whoa, it's hard to follow ya, sir, especially at this hour (11 p.m. CET).
Would you please graphically sketch your goal, in a flow chart fashion..?
Murph
Message 3 of 6 (375 Views)
03-28-2013 03:13 PM in reply to: torentrue
Mapexport to sdf/shp select both the Object Data and link table as the data. Then mapimport and create object data from the attibute data.
Murph
Supportting the troops daily.
braudpat
Message 4 of 6 (362 Views)
03-29-2013 01:28 AM in reply to: Murph
Hello
+1 with Murph, it's the best solution and very easy ...
So you get ALL Infos as Object Datas and now you are autonomous !
Bye, Pat
Bye, Pat
Active Contributor
torentrue
Message 5 of 6 (328 Views)
04-08-2013 10:26 AM in reply to: torentrue
Thanks for your help. I apologize for the delay in responding.
Thanks again,
Murph
Message 6 of 6 (317 Views)
04-08-2013 03:04 PM in reply to: torentrue
Thanks again,
No problem, as long as it works for you.
Murph
You are not logged in.
Ask the Community
