wrote in message news:5315079@discussion.autodesk.com...
I have street maps where i have following features:
1. Street center line (with object data attribute about street segment)
2. Street node where i must specify trough which node i must force rout, and
which node i must avoid.
I must have data i dwg where i have original map and topology data stored in
SQL database where i must change map restriction for each specific day
(depending on work on some roads, which road will be close this day)
Questions are:
1.How to organize that each time when i ask for route, route topology will
be read from database records - not from dwg file?
2. How to maintain database record if i add new node or new street, because
i must add just new records to database and keep all olds data in database?
Any idea or recommendations?
I hope someone has an answer for this, had a similar problem last year.
