AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Text Files in .shp file
3 REPLIES 3
349 Views, 3 Replies
When I import my shape file into my drawing I am not getting the text file to come in with the roads. Any suggestions are welcome. Thanks
3 REPLIES 3
antoniovinci
It happens 'cause a shapefile never shows its attributes (even text) so you gotta label them, sir.
in reply to: antoniovinci
Ok, I am brand new to shape files. How do I label them?
hence_the_name
importing SHP and labelling afterwards is a frequently asked question - you will find more then one discussion about it in the forum.
If you are new to Map:
- either import the SHP including the attribute data (an import option) and then use Map's annotation feature
or
- just connect to the SHP file through FDO and label it using DisplayManager's StyleEditor
These basic tasks are also described in the online help system:
http://docs.autodesk.com/MAP/2012/ENU/landing.html
Good Luck,
Rob
http://raumpatrouille3d.blogspot.ch/
”Boost
