AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Text Disappears when Converting SHP to DWG
7 REPLIES 7
Message 1 of 8
nsummitt
1298 Views, 7 Replies
I bring in the shapefile with the FDO connections and place a label using the attributes from one of the fields.  These attributes are set to a constant map space size.  Before I export to a dwg, text in the center vanishes when I zoom to certain levels.  Surrounding text still appears.  I zoom in until all the text appears.  (BTW These are PLSS section numbers so they are quite consistent and order in their physical placemnet).  Then I export to dwg and find that text is missing in the dwg.  What is odd is that I am missing section numbers for a township and range in the "middle" of the data set.  It is like a square was removed, because all surrounding sections are there.  This is getting quite annoynig and I know from what water cooler talk that many in the office are quickly losing patience with autocad and the faith in its abilities is quickly crumbling when it comes to gis data.  everything just seems so counter productive.
Using Acad Map2010
and someday when I click to open the style editor, I hope my properties bar won't disappear.  And then again someday, Autocad may actually fix some of these glitches and provide you with software that is of the value that was paid for it.
7 REPLIES 7
Message 2 of 8
nsummitt
in reply to: nsummitt
Message 3 of 8
Murph_Map
Have you read this?
Murph
Supporting the troops daily.
Message 4 of 8
nsummitt
in reply to: Murph_Map
Murph,
Thanks for helping start my new year off right.  Tremendous help.
Nat
Message 5 of 8
NateMoore
You might also take a look here: http://beingcivil.typepad.com/my_weblog/2012/02/fine-tuning-fdo-labels.html , especially as you are exporting to DWG anyway.
Nate Moore, GISP
Geospatial Premium Support Specialist
Global Services
Autodesk, Sarl
Message 6 of 8
Murph_Map
in reply to: NateMoore
Nate,
You missed this "Using Acad Map2010" in the first post.  🙂
Murph
Message 7 of 8
nsummitt
thanks for that catch Murph.  BTW  do you know why opening the shapefile style editor forces the properties tab to close?  I have been emailing autocad about this for almost a year now and no one responds.  I have seen it occur in 2010 thru 2012
Message 8 of 8
Murph_Map
No idea on why it does that with the property palette,in fact I didn't notice it did that until you posted about it the other day. It may be a dotnet issue.
Murph
”Boost
