AutoCAD Map 3D General
nsummitt
Message 1 of 8 (551 Views)
Text Disappears when Converting SHP to DWG
551 Views, 7 Replies
01-02-2013 08:28 AM
I bring in the shapefile with the FDO connections and place a label using the attributes from one of the fields.  These attributes are set to a constant map space size.  Before I export to a dwg, text in the center vanishes when I zoom to certain levels.  Surrounding text still appears.  I zoom in until all the text appears.  (BTW These are PLSS section numbers so they are quite consistent and order in their physical placemnet).  Then I export to dwg and find that text is missing in the dwg.  What is odd is that I am missing section numbers for a township and range in the "middle" of the data set.  It is like a square was removed, because all surrounding sections are there.  This is getting quite annoynig and I know from what water cooler talk that many in the office are quickly losing patience with autocad and the faith in its abilities is quickly crumbling when it comes to gis data.  everything just seems so counter productive.
Using Acad Map2010
and someday when I click to open the style editor, I hope my properties bar won't disappear.  And then again someday, Autocad may actually fix some of these glitches and provide you with software that is of the value that was paid for it.
nsummitt
Message 2 of 8 (549 Views)
Re: Text Disappears when Converting SHP to DWG- image of missing data
01-02-2013 08:34 AM in reply to: nsummitt
*Expert Elite*
Murph
Message 3 of 8 (531 Views)
01-02-2013 10:07 AM in reply to: nsummitt
Have you read this?
Murph
Supportting the troops daily.
nsummitt
Message 4 of 8 (528 Views)
Murph,   Thanks for helping start my new year off right....
01-02-2013 10:20 AM in reply to: Murph
Murph,
Thanks for helping start my new year off right.  Tremendous help.
Nat
Product Support
Message 5 of 8 (486 Views)
01-04-2013 02:45 AM in reply to: nsummitt
You might also take a look here: http://beingcivil.typepad.com/my_weblog/2012/02/fine-tuning-fdo-labels.html , especially as you are exporting to DWG anyway.
Nate Moore, GISP
Geospatial Premium Support Specialist
Global Services
Autodesk, Sarl
*Expert Elite*
Murph
Message 6 of 8 (479 Views)
01-04-2013 04:17 AM in reply to: NateMoore
Nate,
You missed this "Using Acad Map2010" in the first post.  :smileyhappy:
Murph
nsummitt
Message 7 of 8 (473 Views)
01-04-2013 06:36 AM in reply to: nsummitt
thanks for that catch Murph.  BTW  do you know why opening the shapefile style editor forces the properties tab to close?  I have been emailing autocad about this for almost a year now and no one responds.  I have seen it occur in 2010 thru 2012
*Expert Elite*
Murph
Message 8 of 8 (462 Views)
01-04-2013 03:45 PM in reply to: nsummitt
No idea on why it does that with the property palette,in fact I didn't notice it did that until you posted about it the other day. It may be a dotnet issue.
Murph
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
