I am developing a base plan from RTK survey shots as I have done many times in Map 2006. After I've connected the points and drawn my physical features, I insert the underlying TIFs from our statewide orthophoto set as a check. These are tifs along with .trf, .aux, .rrd, *.tif.xml files. This latest drawing was created in Map 2006 with no problems inserting the tifs. In 2007, using the same method, they insert in the wrong place and 12 times larger. I brought the drawing back into 2006 and it still inserts in the wrong place. Only if I start a new blank drawing in '06 will they insert in the correct spot. I CAN bring them into the correct spot using Display Manger, but the resolution is degraded. (They are .25m resolution tifs) Any thoughts?
