AutoCAD Map 3D General
Active Contributor
Message 1 of 8 (131 Views)
Symbols from raster images blocks
131 Views, 7 Replies
02-26-2008 08:59 AM
Hi!
I have block file. Some of blocks are drawing objects and some blocks are small raster images. I have point layer, and I have connected to that layer through display manger. Then I try to edit layer syle, trying to apply symbols from block file. Every simblo is visible, except those raster picture symbols. I can see symbol name in library but symbol is not displayed on layer.
thanx
Message 2 of 8 (131 Views)
Re: Symbols from raster images blocks
05-10-2010 05:25 AM in reply to: enter-st
hi,
I have the same problem
no one has solved this problem?
andrea
*Murph
Message 3 of 8 (131 Views)
05-10-2010 06:14 AM in reply to: enter-st
What problem? You replied to a thread from 2005 and a lot has changed
between those 5 years.
Can you provide more info and what it is you are trying to do? Along with
the version of Map3D you are using?
Murph
http://map3d.wordpress.com/
"andy62" wrote in message news:6388361@discussion.autodesk.com...
hi,
andrea
Message 4 of 8 (131 Views)
05-10-2010 09:16 AM in reply to: enter-st
Hi Murph,
thanks for your answer
but What problem?
the problem is exactly the same of enter-st, despite all changes from 2008 or 2005 (?)
my blocks contain small bmp images and like enter-st said
"Then I try to edit layer syle, trying to apply symbols from block file. Every simblo is visible, except those raster picture symbols".
I use Map3d 2009
regards
andrea
*Murph
Message 5 of 8 (131 Views)
05-10-2010 09:56 AM in reply to: enter-st
Andrea,
Those that use newsreaders for the discussion groups do not see the original
thread from years ago, so that's why I asked what problem. Are you trying to
style the points from a data connect layer or standard AutoCAD objects?
Murph
"andy62" wrote in message news:6388546@discussion.autodesk.com...
Hi Murph,
but What problem?
or 2005 (?)
I use Map3d 2009
regards
andrea
Message 6 of 8 (131 Views)
05-10-2010 10:05 AM in reply to: enter-st
Murph,
now I've got your "what problems" :-)
thanks
I trying to style the points from an sdf data connection layer
andrea
*Murph
Message 7 of 8 (131 Views)
05-10-2010 10:29 AM in reply to: enter-st
There's no easy way of doing it. What you need to do is convert the block to
a image file (pgn format) then used the enhanced stylization options.
This will give you an idea on what is involved.
http://map3d.wordpress.com/2010/01/14/custom-line-types-with-data-connect/
This may of be of some help also for the point style.
http://www.rand.com/imaginit/1/pdfs/technology/software/building_symbol_libraries_with_autodesk_mapguide_enterprise_2009.pdf
I haven't try it for points.
Murph
"andy62" wrote in message news:6388593@discussion.autodesk.com...
Murph,
thanks
andrea
Message 8 of 8 (131 Views)
05-10-2010 11:42 AM in reply to: enter-st
mmmh!
nothing to do!
I insert a block width image on C:\Program Files\AutoCAD Map 3D 2009\Sample\db_samp.dwg file
and I wrote two xml files (the difference is only the name of block in blockname tag)
the fisrt work width this point style with an graphic block:
false
false
Centimeters
DeviceUnits
0.3
0.3
0.0
CHAIR7
FFC69C6D
FF726358
the second does not work width this point style with an image block:
false
false
Centimeters
DeviceUnits
0.3
0.3
0.0
person
FFC69C6D
FF726358
in the enhanced stylization options and the document that you've suggested (building_symbol_libraries_with_autodesk_mapguide_enterprise_2009.pdf) I have not found solution.
But a specific reference could be reading this sentence:
The image itself may either be specified in the Content element as base 64 encoded PNG.
I will try tomorrow with a similar image
regards
andrea
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
