AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Survey file ?
3 REPLIES 3
320 Views, 3 Replies
Survey file ?
I am a surveyor who currently uses Carlson Software to process all of my data; however, I have been given the oppurtunity to explore Autocad Map 3d as a possible replacement.  Do I need a seperate program to work along with Autocadd Map 3d to process my data or is a cogo program already contained inside of the Autocadd platfrom?
3 REPLIES 3
tjmapper
Take a look at this.
http://docs.autodesk.com/MAP/2013/ENU/filesMAPUSE/GUID-75F6B64A-BB29-4EBA-89E4-D70AC48E48B9.htm
That what your looking for?
What formats does your survey data come in? AutoCAD Map can access a boat load of different data sources.
tjmapper
tjmapper....thank you SO much for this quick insight...I have limited time to jump on here and kick things around so this is a huge help in me getting started!
”Boost
