AutoCAD Map 3D General
Active Contributor
Message 1 of 5 (247 Views)
Style Point Rotation with Map 2013
247 Views, 4 Replies
06-11-2012 07:03 AM
I'm using Map 2013 and not seeing how to choose to use an expression to rotate symbols of attached shp data (see attached png file). I see where you can put in a numeric value but that's all.  Maybe I am just not seeing something?
The "help" says you should be able to use an expression to rotate a symbol.
Alicia
Product Support
phil_borycens
Message 2 of 5 (223 Views)
Re: Style Point Rotation with Map 2013
06-12-2012 03:16 PM in reply to: amm30165
When I try this, there is a drop-down arrow available to me for Rotation. One of the options there is to Use Expression. Your dialog looks a little different from mine. Are you on Windows XP? Or do you have some custom display theme running in Windows that prevents this drop-down arrow from appearing?
Phil Borycens
Alfred.NESWADBA
Message 3 of 5 (220 Views)
06-12-2012 03:22 PM in reply to: amm30165
Seeing your screenshot my opinion is the OP has set the FontSize to > 100% in his Windows-options.
That makes a lot of dialogs looking bad (and indeed hiding controls), so set it back to 100%.
- alfred -
Alfred NESWADBA
Active Contributor
Message 4 of 5 (206 Views)
06-13-2012 05:55 AM in reply to: phil_borycens
I am not using a custom display.
I have Windows XP.
___________________________________________
   Operating System: Windows XP Professional (5.1, Build 2600) Service Pack 3 (2600.xpsp_sp3_gdr.111025-1629)
           Language: English (Regional Setting: English)
System Manufacturer: LENOVO
       System Model: 6075CTO
               BIOS: Lenovo ThinkCentre BIOS Ver 2RKT38.0
          Processor: Intel(R) Core(TM)2 Duo CPU     E4500  @ 2.20GHz (2 CPUs)
             Memory: 3062MB RAM
          Page File: 494MB used, 5501MB available
        Windows Dir: C:\WINDOWS
    DirectX Version: DirectX 9.0c (4.09.0000.0904)
DX Setup Parameters: Not found
     DxDiag Version: 5.03.2600.5512 32bit Unicode
____________________________________________________________
I will be switching to a new computer with Windows 7 and will go to the 64-bit with Map 2013.
Maybe that will be an improvement, we'll see.
I will post a note if the change resolves the issue.
Thanks for your reply.
Alicia
Active Contributor
Message 5 of 5 (200 Views)
06-13-2012 06:29 AM in reply to: Alfred.NESWADBA
I changed the font size and now I can see the complete pull-down choices.
Thanks you so much!
Chalk one up in the RESOLVED column!
Alicia
You are not logged in.
Ask the Community
