AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Snapping and Viewing of Shapefile Features in Map
1 REPLY 1
304 Views, 1 Reply
I have several shapefiles that I have brought into a new autoCad drawing all with the same coordinate system. All display fine when zoomed out to the extents but when I zoom in the features dissappear. The scaleing is set to the default 0 to infinity insode of the styleing so they should dissapear like they are or like one would think if that was set to something else.
I also can not snap to these features while zoomed in either.
What would be causing this?
1 REPLY 1
hence_the_name
hi,
if only some features disappear while zooming in - could be that the SHP index (*.idx)  file is damaged.
Just delete the idx files.
Applies to older an current version:
http://docs.autodesk.com/MAP/2013/ENU/files/readme-map.htm - search for "idx"
rob
http://raumpatrouille3d.blogspot.ch/
”Boost
