Walt,
In terms of AutoCAD shp files are text files, in ESRI terms shp files are
part of their graphic files. ERSI uses three files (shp,shx,dbf) to display
one type of object. Paul is doing the import right other than the drop and
drag.
Murph
"Walt Engle" wrote in message
news:3F273D06.6CEE62C1@houston.rr.com...
> Paul wrote:
> > I've been given some .shp files to import into a map. I can see .dbf,
.sbn,
> > .sbx, .shp, and .shx files with windows explorer but when I try to
import
> > them I have a blank file. I have an old version of Map3 that can see
the
> > files but, can not open them either. I have gone through the menu route
> > Map/Tools/Import.., selected [ESRI shape] but, there is nothing there.
I
> > used [mapimport] on the command line, and got the same results. The
best
> > result so far was dropping the shape file into a new dwg from windows
> > explorer. I get the following message.
> > Bad shape definition at line 1 of *file name*
> > Expected '*n,len,name' shape header
> > I must be missing something.
> > thanks
> > PBrown
> shp files are text files that can be compiled into shx files. However, if
you
> have for instance romans.shp and romans.shx, you don't need to compile the
shp
> as you already have the shx file. As for the other, I am not familiar
with
> them.
